Topic: detached window problem
anok4u2PRO InfinityMember since 2011
Hi, i detached the little window of the "SBDJ freestyler S2L" plugin from the VDJ interface.
I go in the opened freestyler window, no problem.
But when i want to switch back to the VDJ interface...it lags, or seems to possible to do this.
Posted Mon 25 Jul 16 @ 10:40 am
SBDJPRO Infinity Member since 2006
Howcome you are using the old v7 plugin?
Posted Mon 25 Jul 16 @ 12:43 pm
Posted Mon 25 Jul 16 @ 1:20 pm
Posted Mon 25 Jul 16 @ 1:30 pm
Ok, i tried out freestyler8, seemed to work fine
But gotta an issue, while running a FS-cue.
I tapped "beats half speed", worked ok.
But when i untapped it..i won't work to full speed again, got stuck in half speed.
Restarting freestyler, gave me full speed x2.
Resetting fixtures, pressing "trigger" in FS-dmx-sound2light, didn't also help.
Disabled freestyler8, activated SBDJ freestyler S2L did it....cue did work 100% like programmed.
Any idea what i'm doing wrong?
Posted Mon 01 Aug 16 @ 4:37 pm
