For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Visualizations and milk drop do not work...
ewitlesPRO InfinityMember since 2006
Think I found out why... did not have DirectX 9.0c installed. Appears to be working now...
Played a video nicely but cannot get the visuals to show up. But also, when clicking the video button, the screen looks 'chalky'. Did not see this on 8.1
The first image is what the screen looks like w/o video enabled. 2nd picture is normal.
Does not matter if no external display is used or not.
I backed up the 8.1 exe and it's xml file and told 8.2 to make a new xml file
Posted Mon 06 Jun 16 @ 9:17 pm
And cannot use the 8.1 exe file w/ the new settings as it acts rather wonky...
Posted Mon 06 Jun 16 @ 9:39 pm
