Hi folks,
I would like this VST to work, and I am willing to pay if someone is able to solve the problem I am facing.
I don't know if it is VST's related or Virtual Dj's related, but maybe someone are able to help me.
I tested the VST on different PCs with different OS: Win Vista 32, Win7 64 (on 2 different PCs) and Win 10 64.
Virtual Dj 8 (different versions as
The result is always the same: the VST seems to work fine the first time you use it after its installation.
Then you close VDJ, you open it once again, you use DaftFunk and it woks, you use other effects and then you load DaftFunk once again and it doesn't work anymore.
Just try to do this steps on both decks during the same session, not only one one deck. You should face the same problem.
Here a short video of the problem:
http://www.youtube.com/watch?v=q04IMqojgLU
I hope that there is someone out there that could have a clue of what it could be the problem.
Thanksss!
Cheers!
Thanksss!
Cheers!
Posted Sat 16 Apr 16 @ 8:59 am
Here you can download DaftFunk if you want to try it out and see if you can help me with it: https://www.kvraudio.com/product/daft-funk-by-klanglabs
Thanks!
PS: I made some grammar mistakes...sorry about it, but I cannot edit my post (or at least I don't see that option...).
Thanks!
Posted Sat 16 Apr 16 @ 6:39 pm
