I'm getting really bad recording issues whiles recording in Virtual DJ 8 my CPU is running at full and the music skips and crackles never did this with version 7 and it doesn't matter what sound card I use its the same with all of them and doesn't matter whether I have a controller plugged in or not
Posted Wed 30 Mar 16 @ 10:30 am
Some more informations might be usefull.
What is the format you are trying to record?
What quality?
What are your systems specifications?
What quality?
Posted Wed 30 Mar 16 @ 10:47 am
Windows 7, 64 bit, 4 gb ram
Record format is mp3 320kb
Posted Wed 06 Apr 16 @ 5:09 am
while playing virtual dj 8 I am getting static in the speakers and levels are dropping. I am also getting a corrupt message. Is this a software issue?
Posted Wed 06 Apr 16 @ 6:07 pm
VDJ audio output is not original, the sound is fade, jumping between left/right headphone and i know its not the case oF SRS, Echo. however my laptop delivers original sound when played by vlc/other media players. Please help me out!
Posted Wed 06 Apr 16 @ 8:47 pm
I found a solution to my problem I stopped using the display screens that come with my NS7 Mk 3 so instead of the controller been plugged into the screens, and then into my laptop. I just plugged my controller straight into my laptop. I can't use the screens but at least Its glitch free now
Posted Thu 13 Jul 17 @ 2:47 pm
Can't you connect the screens directly to your laptop as well?
Posted Thu 13 Jul 17 @ 3:07 pm
I never thought of that, It's means using 2 USB slots but if its worth a try, I'll try it and let you know :)
Posted Thu 13 Jul 17 @ 4:59 pm
