Forum: VirtualDJ 8.1 Technical Support
Topic: Mixtrack Pro 3 Sound Card No Longer Detected...
nowavePRO InfinityMember since 2015
Hi, I completed the update the other day, and immediately afterwards, the sound card for my Numark Mixtrack Pro 3 would not be found. I even did a system restore, and I think it reverted me to 8.0 but the problem persists. I have used the controller on my Mac, and another Windows laptop both with VDJ8, and it works perfectly fine, and the sound card is detected.
Anyone know what I can do to rectify this? I need urgent help as this is my main laptop for DJing (HP, Windows 8).
Thank you.
Posted Wed 23 Dec 15 @ 12:36 pm
I would start by completely removing it's drivers and re-installing them
Posted Wed 23 Dec 15 @ 1:13 pm
I tried this but it won't play through speekers it will only play through the head phones connected to the controller or the computer what settings can I use to fix this
Posted Sun 03 Sep 17 @ 11:40 am
