Hi,
I need the audio volume 25% when Mic is turned on & the audio volume 90% or 100% when the Mic is turned off with the push of only the letter M for both functions??
I have Virtual DJ 8 and am pretty new to this.
Posted Wed 14 Oct 15 @ 2:15 am
I forgot to say that I need the mapping code please to be able to do this??
Posted Wed 14 Oct 15 @ 11:59 am
dunno what happened my post. Here it is again.
set you key "M" to:
play ? master_volume 100% ? master_volume 25% : master_volume 100%
set you key "M" to:
Posted Wed 14 Oct 15 @ 2:05 pm
My approach would be this:
mic ? mic off & deck 1 volume 100% & deck 2 volume 100% : mic on & deck 1 volume 25% & deck 2 volume 25%
For this action to work you have to define MIC as input in your sound config.
If you set master_volume down, I think the mic volume would also go down.
If you are using more than 2 decks add
deck 3 volume 25% & deck 4 volume 25 & deck X volume.....
to the action.
Same for deck X volume 100%
to the action.
Posted Wed 14 Oct 15 @ 4:39 pm
Thankyou very much PachN.
It is working like a dream and the mic volume is staying full.
Posted Wed 14 Oct 15 @ 7:55 pm
That's where my post went, you cross posted (I thought I was going crazy).
http://www.virtualdj.com/forums/204609/PC_Version_Technical_Support/I_Need_The_Audio_25__When_Mic_On___Audio_100__When_Mic_Off_With_1_Keybord_Key__.html
Posted Wed 14 Oct 15 @ 8:59 pm
I have been playing around with a workaround for a softer mic duck as opposed to the hard level cuts I have seen on several posts.
I ended up settling for the following based on plagiarizing several prior posts (thank you to all contributors) :
mic ? mic off & repeat_start_instant 'currentdecklevelup' 10ms 11 & level 100% ? repeat_stop 'currentdecklevelup' : level +5% : mic on & repeat_start_instant 'currentdeckleveldown' 10ms 11 & level 45% ? repeat_stop 'currentdeckleveldown' : level -5%
Its not without potential flaws as it reduces / increases the level only on the current deck, but if its of help to anyone, here 'tis, and someone might be able to extend / expand or improve on it.
Posted Mon 04 Jan 16 @ 7:00 am
Posted Mon 04 Jan 16 @ 10:18 am
