Hello im starting to learn to dj, now i want to buy a controller, the options are:
Hercules Instinct
Hercules DJ 4 Set
Question: has the DJ 4 Set hot cues? And how many, i cant find it on the webs.
I know the instinct has 4, but i think the dj 4 set is better. How many hot cues has dj 4 set?
Btw i dont care about 4 decks, or 2 decks, gonna use 2 anyway.
The downside of instict for me is, the pitch isnt a slider, but i dont think i use pitch often.
Hercules Instinct
Hercules DJ 4 Set
Posted Mon 02 Mar 15 @ 3:51 pm
Hi, I got an Instinct and it is pretty good in that stage. But it is definitely insufficient even for bedroom djing.
I ordered a Gemini GV4, since I was feeling to play with a toy. I will keep the Instinct for practical issues
I would recommend you to go up for a bigger type. Denon MC2000 or Gemini GV2V for instance.
Posted Tue 17 Mar 15 @ 2:57 pm
