Topic: L/R Balance An Individual Track
ClayDJPRO InfinityMember since 2011
Hi All,
V7; I am trying to use "master_balance" to change the L/R balance using a knob, but not having any luck.
The knob works fine using "master_volume" or "gain", but I would actually like to vary the left/right balance on an individual track. I know that "master_balance" should change the main output L/R balance, but even that would be acceptable if I can get it to work.
Anyone know how I can get "master _balance" to work, or another way (using script) to change the L/R balance on an individual track using a knob?
Thanks in advance.
Posted Mon 02 Mar 15 @ 1:20 pm
What sound setup do you use ?
For "master_balance" to work on VirtualDj 7 you need to use "Output->Headphones" on your sound settings.
Posted Mon 02 Mar 15 @ 2:34 pm
Thanks for the response George.
I am using the advance sound setup for two deck output with external mixer (not using any headphone config in advance setup).
Any other way to alter the L/R balance on a track?
Thanks again.
Posted Mon 02 Mar 15 @ 2:57 pm
There's a balance sound effect by SBDJ available in downloads
Posted Tue 03 Mar 15 @ 6:32 am
