Forum: Addons
Topic: Audio Cut8
SBDJPRO Infinity Member since 2006
Posted Fri 06 Feb 15 @ 10:59 am
idj4himPRO InfinityMember since 2009
Dude you are the best. i missed having audio cut. works great. thank you.
Posted Fri 06 Feb 15 @ 7:38 pm
Yes I SECOND that emotion! Loved this effect in Version 7 and SO happy to have it in 8! Thanks a million!
Posted Sat 28 Feb 15 @ 2:36 pm
olufemiPRO InfinityMember since 2010
What exactly is AudioCut8 ? What does it do ?
Posted Mon 09 Mar 15 @ 1:53 pm
beat aware Gater effect, on the volume. On,Off,On,Off
Posted Mon 09 Mar 15 @ 6:08 pm
ledometPRO InfinityMember since 2015
Would someone please make a small explanation about this ?
I mean how to use it.
Posted Mon 16 Mar 15 @ 5:28 am
just activate the effect, it's also known as a gate fx.
Posted Fri 20 Mar 15 @ 9:21 pm
One of those "first world" kind of bugs/annoyances'
This FX is driven by the CBG, it doesn't work if you're not running a cbg (having a dedicated sample deck)
in instances of no cbg or a stopped cbg (I use vsts to sample loop) could it work off sample bpm and sample start to trigger, a stopped cbg is trickier... erm go off bpm and have a shift dial, perhaps.
Posted Thu 02 Apr 15 @ 5:36 pm
Is there anyway we can get the Parameters switched??
Im gonna go out on limb and say most people here will use multi effects so on most controllers the 1st knob will be the main and in my mind the "cut" is the main focus of this plugin. Now for example I use a DDJ SP1 for effects and I have it setup for multi effects (3 different effects for 3 knobs) well in order for me or anyone who has a setup like me we have to now hold down a shift button to adjust the cut. I just cant use the cut like especially when VDJ 7's version was just a single parameter which was the cut.
Can we please get this swapped around?? Please??
Posted Sat 30 May 15 @ 4:07 pm
You can script round it, Something like
effect_select "Audio Cut8" ? effect_slider 2 : effect_slider 1
Posted Sun 31 May 15 @ 5:03 pm
am so new to this, do i make a macro with my controller effect_audio8cut 1 just that ?
Posted Fri 04 Sep 15 @ 2:46 pm
Still wish the parameters were switched so I don't have to use any fancy script and make it possible to use with 1 knob.
Any chance at all of this happening, please??
Posted Sun 19 Jun 16 @ 6:18 pm
Noticed a small bug if beat pos is less than 0 [first beat is later in the track] the effect won't do anything,
Posted Fri 12 Aug 16 @ 4:22 am
Yea this bug exists for me too. If you're playing a song and the beginning doesn't have some sort of drums the effect doesn't kick in. Also the popping sound for when the audio cuts in and out can be a bit annoying. I wonder if it's possible to make it fade in and out so the clicks aren't there.
Posted Sun 27 Nov 16 @ 2:20 pm
Posted Wed 29 Mar 17 @ 2:05 am
mokiLE userMember since 2006
i'm searching for audiocut8 plugin but i can't find anywhere!
could you please reply with a link or whit plugin himself?!
i had but i just lost after format my pc and i 'm pretty despertate.
thank you all
Posted Sat 13 Feb 21 @ 8:52 pm
Cut is a native plugin in modern VirtualDJ
You find it on the effect list in the software
Posted Sat 13 Feb 21 @ 9:17 pm
