Forum: Addons
Topic: VirtualDJ 8 skin engine at its best ! by FRUiT - Page: 1
0.3 alpha stage (work in progress)
Details : http://www.virtualdj.com/forums/190684/VirtualDJ_Skins/_NEW___VDJ8__VirtualDJ_8_but_by_FRUiT.html
TIP : The skin is extremely verbose using tooltips
TIP : Each mixer's panel has its own 'Sides' menu
What's new :
-- v0.3 --
0.3c: Long "times" not showing properly
0.3b: Some rhythmzones issues corrected
- better visual handling of swapped / mirrored decks
- tons of visual details adjusted
- 'clone deck' bug fixed
- double-able waveform's height
- timecode options (bypass, absolute, relative, smart)
-- v0.28 --
0.28c: bugs, glitches, mistakes fixed
0.28b: possible fix for a 'clone deck' related issue
- less lines, more features
- 2 new mirrored forms schemes
- revamped some buttons
- can flatten ui (only transport and knobs now)
- more knobs colors (green for headphones, neutral for custom knobs)
- other minor improvements and bugs wiped
-- v0.2 --
- Code cleanup / bugs correction
- Dimmed on-screen scratch view
- Main Vu-meter color schemes (per deck - neutral - green)
- Mixer's master tab new behavior (menu)
- Return of the broadcast page
- Rightclick on 'sync' button does autosync-n-play
- Mirrored split waves mode
- Small other improvements
Posted Sun 20 Jul 14 @ 9:16 am
FruitPRO InfinityMember since 2003
0.4
- new 'inverted no grid' form style
- new 'normal browser' view in jukebox
- much less forms resets when toggling stances
- key infos in key panel
- contrasted red and dark icon for played songs
- can loop up to 256
- can hide BPM (show pitch % intead)
- can show eq's in scratchmixer
- can show doubled waves in both jukeboxes
- can monitor gains
- can monitor next cue infos (click on bitrate stat in deck's screen)
- can show phraser on jogwheels (2 sizes)
- customized crossfader curves (dipped, linear)
- flatten-able seek buttons
- jukeboxes minidecks improved / revamped
- beat phaser visual (in progress)
- up to 4 effect slots per deck / more controls
- up to 9 hot cue points with timers
- larger cover art on deck screens (+ still can beattap on gain)
- code cleanup / bugs addressed / bigger font sizes
0.4 FR
- nouveau style de waveform 'inverted no grid'
- nouvelle vue de jukebox 'normal browser'
- beaucoup moins de réinitialisations des waveforms lors des changements de vues
- des infos de note cliquables dans le panneau de la note
- un icône pour les chansons jouées bien visible, rouge, foncé
- capacité de boucler jusqu'à 256 beats
- capacité de cacher le BPM (pitch % à la place)
- capacité de montrer les EQ dans le panneau de scratch
- capacité de montrer les doubles waveforms dans toutes les vues du jukebox
- capacité de surveiller les gains
- informations sur le prochain cue (en cliquant sur la statistique 'bitrate' sur l'écran des platines)
- les jogwheels peuvent battre la mesure (phraser) (2 tailles)
- courbes de crossfader personnalisées (dipped, linear)
- les boutons skip-beat sont applatissables
- mini platines du mode jukebox complètement revisitées et retravaillées
- un visuel beat phaser (en cours)
- jusqu'à 4 slots d'effets par platine / plus de boutons
- jusqu'à 9 hot cues avec des indications de temps
- des pochettes d'album plus grandes sur l'écran des platines (possibilité de taper le rythme sur le gain)
- code amélioré / bugs résolus / polices plus grandes
Posted Sat 09 Aug 14 @ 4:51 am
0.5
- 0.5c: FIX: Vu meter scheme not settable in mixer menu
- 0.5c: FIX: waveview: bigwave: grid not showing
- 0.5c: can edge decks
- 0.5b: FIX: pitch reset not working
- FIX: pitch reset stills visible in mirrored stance
- FIX: holding stop-to-unload in jukeboxes set to 100ms
- FIX: key font clipping in key panel
- FIX: Effect button 2 not showing text
- FIX: browser: played song icon glitching over video icon
- hot cues monitor on jogwheel
- loop monitor on jogwheel
- new alternate art view on jogwheel
- persistent vu-meter scheme / wheel cover art
- can choose RPM in wheel sub menu
- can restore hidden song infos on the fly
- can flatten ui (++ buttons)
- can show EQ in videomixer
- big video mode in videomixer
- jogwheel can show video (WIP)
- filters in videomixer
- master effect in videomixer
- can load / save deck-sets
- song infos in jukeboxes
- remaining time blinks in jukeboxes
- waveview: perdeck: ear-line moved left
- waveview: perdeck: center improved (WIP)
- waveview: brightness dimmer
- legend in master's monitor
- big, much more clickable cues on songpos
- hot cues rightclick behavior redefined (click : goto | hold : delete)
- flattened transport lights off when deck is empty
- screen's key info remember it's state (independantly)
- every vertical vu-meter is clickable
- every vertical vu-meter follows color scheme
- beat grid adjusting buttons
- contrasted browser buttons when clicked / selected
- up to 4 master effects
0.5 FR
- FIX: le bouton pitch reset ne réagit pas à l'option 'hide pitch reset'
- FIX: dans les jukebox, l'action 'maintenir' sur le bouton stop réglée sur 100ms
- FIX: la police de la note tronquée dans le panneau de la note
- FIX: le texte du bouton d'effet no 2 absent
- FIX: browser: l'icône des videos visible sous l'icône des chansons jouées
- nouvelle vue alternative des pochettes sur les jogwheels
- les jogwheels peuvent surveiller les hot cues
- les jogwheels peuvent surveiller les boucles
- les jogwheels peuvent montrer la video (en cours)
- potards de filtre dans le panneau video
- 1 effet master dans le panneau video
- possibilité de montrer les EQ dans le panneau video
- mode grosse video dans le panneau video
- l'option des pochettes sur les jogwheels reste en mémoire si vdj est fermé
- le menu wheel permet de changer la vitesse de rotation à la volée
- Les titre/artiste peuvent être restaurés à la volée si cachés depuis une autre skin
- interface applatissable (++ bouttons)
- possibilité de créer / rappeler des configurations de platines (deck set)
- les jukebox peuvent montrer les titre/artiste
- le temps restant clignote dans la posture 'bigwave'
- waveview: perdeck: la 'ligne d'écoute' est plus à gauche
- waveview: perdeck: le centre a été amélioré (en cours)
- waveview: possibilité d'atténuer l'affichage
- le surveillant du panneau 'master' affiche la légende des vu-mètres
- des cues plus gros sur la songpos
- le bouton droit sur les hot cues a évolué (clic : goto | tenir : supprimer)
- les boutons de lecture plats s'éteignent si la platine est vide
- les infos de note sur l'écran des platines gardent leur état en mémoire
- tous les vu-mètres verticaux sont devenus cliquables
- tous les vu-mètres verticaux ont désormais la même couleur
- tous les vu-mètres verticaux gardent les options de couleur en mémoire
- des boutons pour ajuster la grille sous le bouton TAP
- les boutons du browser sont plus contrastés lorsque cliqués / activés
- 4 effets master
Posted Sat 09 Aug 14 @ 4:54 am
Posted Sat 09 Aug 14 @ 5:00 am
Posted Sat 09 Aug 14 @ 6:05 am
Posted Sat 09 Aug 14 @ 6:06 am
Posted Sat 09 Aug 14 @ 6:07 am
Posted Sat 09 Aug 14 @ 6:17 am
Posted Sat 09 Aug 14 @ 6:18 am
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
Very good skin. Solid work Fruit.
Posted Sat 09 Aug 14 @ 11:06 am
Thx but why is it the v0.3 on the new page while all other VERY recent skins are there (such as Silver Sleek).
Also when will I be able to upload something on this page ?
Also I'm afraid but my skin doesn't call "by fruit"
I called it "VirtualDJ 8 but by FRUiT"
Can someone fix this ? as well as put the good motd "V8 skin engine at its best !"
Thanks in advance.
Posted Sun 10 Aug 14 @ 3:34 am
Better?
Posted Sun 10 Aug 14 @ 9:06 am
Yop ^^
No I meant on the "new v8" download page, not the topic's title.
But anyway it seems... not finished... Dunno why it is online yet... Let's wait a bit.
Posted Sun 10 Aug 14 @ 1:39 pm
Fruit wrote :
Yop ^^
In the new addon system for v8, the skin and fx "names" that you set when you upload a new addon, is also the actual filename that will be used when installing the file, and therefore shown to the user inside virtualdj when he select a skin or plugin.
This way there won't be any confusion or overwritting of each other skins.
(it's also needed for the new "popularity" score, which measure exactly how much a skin or plugins is really used inside virtualdj itself)
So the name must now have more restrictions. First it needs to have only characters that can be used in a filename, obviously, but also it cannot contains the word "virtualdj" for example. And, because the name is what will appear in the skin list or fx list inside virtualdj, it shouldn't be too long (otherwise it will not fit in the list).
Posted Sun 10 Aug 14 @ 9:58 pm
Oh! the pitch reset on right click is no working. Is this correct???? Not go to Zero!!
Posted Mon 11 Aug 14 @ 4:22 am
sclavel wrote :
Fruit wrote :
Yop ^^
Hello ^^
Thank you dear for your reply.
I noticed blacklisted words when trying the new upload page. T's a kind of worry for me but, should not be a big matter.
Keep up the good work my friend !
Posted Fri 15 Aug 14 @ 6:48 am
First of all, please make sure you got the last version of the skin (0.5d).
Then, to instant reset pitch you may :
- triple left click the pitch reset button
- hold right click 2s on the pitch reset button
I did those modifications because some djs don't like the double-click ability.
Posted Fri 15 Aug 14 @ 6:52 am
-- v0.6 -- 2014-09-28
- FIX: left pitch reset button not lighting during motion reset
- skin remains its state through shutdowns / skin change (wip)
- 15 color schemes (wip)
- some controller options
- up to 10 saved loops
- jogwheel lights on when holding platter
- transport compact layout
- revamped loop panel with full loop selector
- genre year rating album on deck's screen
- topbar: clock: can show cpu percentage
- topbar: AC power monitor
- waveview: (all): gridlines settings
- songpos highly customizable
- stripe-able browser
- seamlessly integrated 4 decks swap version (wip)
Posted Mon 29 Sep 14 @ 4:18 am
Just to give everyone an idea of what the colorization looks like.
Posted Mon 29 Sep 14 @ 7:00 am
83%
