hi i have been trying to figure out how to broadcast pc to pc direct only ... when i hit broadcast gives me the link but when i check the link from an external network and internal network i hit play but NO sound comes out and it DOES not display the song info ... I am only interested to making this pc to pc broadcast to work ...Any help will be aprecciated it thanks..!!!
Posted Sat 19 Jul 14 @ 7:51 pm
Hi I am having the same issue, I just got vd8 and tried to broadcast pc to pc and it does the same thing. No sound , and the play option for your listeners disappears after a while. Is there a tutorial or set up guide for this ? Is there a bug? Help
Posted Sun 07 Sep 14 @ 10:19 am
hi.... how are u trying to BC?
via a controller?
via a controller?
Posted Sun 07 Sep 14 @ 11:00 am
ffs... i just seen the date of the first post
here, look at this link
http://www.virtualdj.com/forums/188065/VirtualDJ_8_bug-report_Forum/PC-to-PC_Broadcasting_not_working_.html?search=broadcast&page=1
Posted Sun 07 Sep 14 @ 11:05 am
I am having the same issue with PC to PC.
Posted Sat 11 Oct 14 @ 10:47 am
I am also one of those having the same problem. There seams to be no easy fix
Regards
John
Regards
John
Posted Sat 05 Sep 15 @ 9:20 am
