i seen videos on youtube on how to midi map knobs on the american audio 10mxr to do different things. how can i do this in VDJ ?
Posted Tue 05 Nov 13 @ 12:21 pm
It's in the VDJ manual (user guide) under the title mappers.
Posted Tue 05 Nov 13 @ 12:25 pm
Easy way:
Config Menu
Mappers tab
Hit green plus then key learn. Then push the button or slider you want to use, then hit action learn. Use your mouse to select on the skin the element you want to control. You can also type the action in the window next to action learn. Suggestions will come up as you type. It can take some time, but you can make buttons, knobs and sliders do all kinds of stuff.
Config Menu
Mappers tab
Posted Tue 05 Nov 13 @ 12:40 pm
thanx for the fast replies. i never did the midi map stuff. so ima give it a try right now :-)
Posted Tue 05 Nov 13 @ 12:49 pm
if your mapping the eq knobs you might want to use
fake_eq_low
fake_eq_mid
fake_eq_high
Using those commands will only change the knobs on the skin without affecting the sound
fake_eq_low
fake_eq_mid
fake_eq_high
Posted Tue 05 Nov 13 @ 1:30 pm
fake_eq_low
fake_eq_mid
fake_eq_high
fake_eq_low
fake_eq_mid
fake_eq_high
Would it be like a double effect otherwise?
Software and hardware both adjusting the sound?
Posted Tue 05 Nov 13 @ 1:43 pm
yep that's correct
Posted Tue 05 Nov 13 @ 2:22 pm
well ive been at it for like an hour with no luck.. so my fellow dj\'s this is what im trying to accomplish. on my american audio 10mxr mixer to cue the headphones you have to rotate a dumb knob left or right to cue either side. im used to push button style headphone cue. so im trying to map the two hi/low kill knobs they push down to activate & deactivate. or the hot cue buttons. i followed the manual but no luck please my picture
Posted Tue 05 Nov 13 @ 2:44 pm
deck 1 pfl
deck 2 pfl
I don't have anything setup to try it out. What have you tried so far.
Why not use it as is shouldn't take long to get used to it.
deck 2 pfl
Posted Tue 05 Nov 13 @ 3:13 pm
