| Author | - Topic: Horizontal keystone correction for video output - |
Hi everyone! Wondering if there's an effect that I've overlooked that can apply horizontal keystone correction to the video output. I use an LED projector (Acer K11) for most of my events, and while it has vertical correction, having a horizontal option would be handy as it is sometimes difficult to get the space to get the projector sitting square on the screen! Any ideas? Gareth. |
It's something we run into every now and then... NVidea used to have a horizontal keystone correction but it's not updated anymore (http://www.nvidia.com/object/feature_nvkeystone.html) It doesn;t support Vista and later. I did found a page with programs that could do the job: >>HERE<< I haven't tested any-one: Digital horizontal correction is not recommended, because it will distord your video and produce artifacts. Maybe you better save up and buy yourself a projector with build-in horizontal correction like the later models of Hitachi. |
I've got a plugin in the works that lets you 'reshape' the video output from VDJ which should accomplish what you are asking. |
SBDJ wrote : I've got a plugin in the works that lets you 'reshape' the video output from VDJ which should accomplish what you are asking. Scott your a MAD GENIUS!! Can you send me a small peice of your brain, lol!! |
hey SBDJ, i'm also looking rapidly for some solution i have the same problem with keystone. There is no projector which can correct an image more than 35-40 degrees. Could you help me also? Thanks in advance!! peter |
Sounds great re the plugin - can you keep me up to date on the progress? |
Hi Scott, was wondering if there was a progress update regarding the plugin for VDj for horizontal keystone? |
No, but I'll sort a test version out - the basic reshape is functional, I've just not added the stuff that lets you add multiple shapes. |
I'd be interested on this as well. I use a projector that does not do Horz-Keystone (Optoma). I use the HDMI connection. |
