Greeting, I would know how to set virtual dj's buttons and controls with the external midi controller Evolution USB UC 16 , Thanks !
Posted Thu 07 Jul 05 @ 2:24 pm
Not sure if console version supports that, and sure not a cracked version
You would first of all have to get the full legal version for that kinda support :)
Posted Thu 07 Jul 05 @ 2:40 pm
Yes that's right , but I would check the software before buying it.
My big problem is how to set every effect slider to my controller's knobs , and if it's possible ,
to set play ,pause and stop to the numeric buttons.
VDJ is a great software , yeah, but i need a external controller for that , if my Evolution uc 16 controller isn't ok, which one will be the good one ?
Thanks
Thanks
Posted Thu 07 Jul 05 @ 4:49 pm
I think the UC16 should work fine...
You need to work a bit with shortcuts
I know the UC33 is recommended by the VDJ developers, and even a shortcut file for download :
http://www.virtualdj.com/download/shortcuts_uc33.xml
Maybe u can look at that shortcut file....
What you need to do, is to make each slider (midi) connect to a shortcut (sample_volume_1 etc).
It should work just fine with the UC16 as well :)
Posted Thu 07 Jul 05 @ 5:25 pm
hope to see you as a full member soon :) remember the cracked version have lots of bugs...
having the full version will give you full support, effect downloads, and lots more :)
Posted Thu 07 Jul 05 @ 5:29 pm
I've tried using the xml shortcuts posted, but it no worked .
Tried also using but my Vdj doesn't recognize the command.
What's the right command for controlling samples sliders (volumes) ??
my Vdj version is the 1.9
Thanks
Thanks
Posted Thu 07 Jul 05 @ 5:53 pm
eh... WHAT ??
Virtual DJ 1.09 does NOT have sampler engine like later versions..
It can probably NOT be controlled by midi commands.. and might not even have buildt in shortcuts for "old sampler"
you need the full version of VDJ, where all sliders and buttons can be asigned to midi (UC16), and it will all work fine..... :)
Posted Thu 07 Jul 05 @ 8:22 pm
