Forum: PC Version Technical Support - Topic: serato timecode vinyl & hercules rmx problem please help - Page: 1
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ forums
PC Version Technical...
serato timecode...
Page : [>] [>>]
Author - Topic: serato timecode vinyl & hercules rmx problem please help -
Ryan_Harmonic
Limited edition user
Posted Wed 20 Jan 10 @ 12:18 pm
ive got a hercules rmx , and have vdj . ive plugged my techniucs 1210 into the correct input on the rmx , and i have searto scratch live control vinyl - says second edition cv02 scv - 12002 . in vdj the timecoded vinyl doesnt work properly pull record back still goes forward etc im guessing all the problems are to do with not having a proper signal .
in vdj im not getting the circle image in the signal srength box i get a \ see pic:
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/vdj.jpg
i hope i have the correct timecode vinyl , says second edition on them . ive checked youtube on how to set a rmx up with vdj timecode etc , but i cant work out what im doing wrong . tried rmx in asio mode everything
please help
Ryan_Harmonic
Posted Wed 20 Jan 10 @ 12:20 pm
4got to say i never get a circle image atall
heres another pic with other info :
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/vdj2.jpg
DJ Phatso
Experienced pro user
Posted Thu 21 Jan 10 @ 6:39 am
What version of VDJ are your using exactly ?
Ryan_Harmonic
Posted Thu 21 Jan 10 @ 10:50 am
using vdj 6.0 , also put vdj 5.2 on my laptop to see if would be better on a older version of vdj but still does exactly the same as in the pics above . please help :(
Ryan_Harmonic
Posted Thu 21 Jan 10 @ 1:31 pm
5.2 , never tried timecoded vinyls b4 . wanted to get a hardware mixer (normal mixer) eventually but thought the rmx can be used with timecoded vinyls
DJ Phatso
Posted Thu 21 Jan 10 @ 1:38 pm
The latest version available for the Rmx LE version is 5.2.2 . However,using timecode will only work for 5 min with this version.
If you really want to get a better idea about using Timecode, you should install the latest Trial verison (v6.06), which included all the major improvements that were done regarding timecode since 6.03.
From there, you will be able to apply the recommendations from the Wiki:
http://www.virtualdj.com/wiki/TimeCode%20Config.html
Ryan_Harmonic
Posted Thu 21 Jan 10 @ 2:11 pm
just downloaded 6.06 version and have the same problem , really confused :/ heres the image from version 6.06 , thought it might be the needle but it plays normal records fine - any ideas any1
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/vdj606.jpg
thanks for anymore help
andreanegri
Professional edition user
Posted Thu 21 Jan 10 @ 3:10 pm
Did you try to change the timecode vinyl type from the combo box?
I have rmx and serato vinyl and vdj 6.0.5 pro and it work fine...but I did only a fast test.
Andrea
DigiCon
Posted Thu 21 Jan 10 @ 3:17 pm
Hey there. This may sound crazy, but try putting some extra weight on the needle. The turntable may not be set-up correctly. (balanced) Start the timecode and as you see the line gently push the arm of the table downward as if you are weighting it. See if the image changes as you do this. had a similar issue when putting new needles on the tables once and realized it was simply a weight issue. Doesn't hurt to try.
Ryan_Harmonic
Posted Thu 21 Jan 10 @ 3:42 pm
thanks for replying , really doing my head in . ive selected the right vinyl type in vdj , tried all different types etc to see any change . ive even just installed vdj 6.06 trial on another laptop and used latest drivers etc and does the same thing . just this \ for a signal . ive added more weight etc nothing changes , . the needles on the 1210 plays normal vinyl fine . so im guessing it must be either rmx , but ive had no probs with anything else on it , or the serato timecode vinyl , but it says 2nd edition etc so im completely lost , im going mad !
Ryan_Harmonic
Posted Fri 22 Jan 10 @ 11:07 am
heres some more pics :
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/P1260813.jpg
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/P1260814.jpg
also recorded a little video , when pushing record foward or backwards the music just goes forward
http://s279.photobucket.com/albums/kk134/Ryan_Guppy/?action=view&current=P1260815.flv
dont know what to do .
Ryan_Harmonic
Posted Mon 25 Jan 10 @ 10:21 am
bought a couple of new stylus to see if that makes any difference waiting for them to arrive :(
PongKador
No license user
Posted Tue 26 Jan 10 @ 12:12 pm
Hey,
did you tried to select PHONO instead of Line 1? (on the Hercule RMX)
I got no signal until I switch that...
Ryan_Harmonic
Posted Tue 26 Jan 10 @ 3:18 pm
yeah tried that , its just i only get this \ signal , tried everything .
Ryan_Harmonic
Posted Thu 28 Jan 10 @ 10:10 am
just got new stylus , still all same problems :( . dont know what to do not got a clue what the problem is .
PongKador
No license user
Posted Thu 28 Jan 10 @ 2:56 pm
This is strange...
I have the Hercule RMX too with TT500 and CV02 Serato Vinyl and its working fine...(with some small issue, but ok for now)
I got the circles... I even connected to a normal mixer and its working fine!
Its not the needle since its working fine with other vinyl.
It doesnt seem to be the connection...
Did you see these videos :
http://www.youtube.com/watch?v=dp6USvPoZ0k&feature=PlayList&p=4DC26196EE9BCA29&playnext=1&playnext_from=PL&index=1
http://www.youtube.com/watch?v=eYW5PaZnhbs&feature=PlayList&p=4DC26196EE9BCA29&index=0
Would it be possible that the serato vinyl is not good? Did you tried the B side?
Ryan_Harmonic
Posted Thu 28 Jan 10 @ 3:44 pm
yeah ive tried both sides of the vinyl , also watched those vids thats why thought should be pretty straight forward to do it all . my serato vinyls look like they have a different label than most peoples on youtube . but they say second edition on them etc , and vdj reconising them .
Ryan_Harmonic
Posted Sun 31 Jan 10 @ 6:41 am
heres some pictures of the serato time coded vinyl im using , noticed that most people on youtube etc have a different label on the vinyl say rane etc also the front sleeve says second edition on them . do i have the correct vinyl ?:
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/P1070082.jpg
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/P1070083.jpg
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/P1070087.jpg
pickleweaseal
Posted Thu 04 Feb 10 @ 12:04 am
Hi, I'm not sure if this will help but...I had the same problem, it would play foreward but not backward, I came to find out thru alot of trying diffrent things that RCA leads one is foreward and the other is the backwards, it turns out that 1 of my RCA leads were broken, so in your case if it's not that its maybe your jacks on your rmx , either way its not reading half of your turntable
landpirate
Posted Wed 24 Feb 10 @ 5:31 pm
yeah looks like its only receiving one side of the audio
Page : [>] [>>]
Site map
Software
Membership
Goodies
VirtualDJ Pro Full
VirtualDJ Pro Basic
VirtualDJ Broadcaster
VirtualDJ Home FREE
VirtualDJ LE
Comparison
Numark CUE
VirtualVinyl
VirtualDJ iRemote
AtomixMP3
eJay DJMixStation
DJ-Box
Why VirtualDJ?
Vdj for Video
Vdj for Turntablism
Vdj for Club DJ
Vdj for Mobile DJ
What's new
Features
Screenshots
VirtualDJ Home FREE
User Manuals
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Effects
Controllers
Languages
Samples
Grafx
Tools & Drivers
Forums
Users Network
Music Groups
Wiki & Manuals
Radio
Magazine
Social Web
Create a login
Atomix Productions
Privacy Policy
VIP DJs
Ask a question
View your tickets
Wiki & Manuals
