Forum: PC Version Technical Support - Topic: Hercules RMX With Window 7 64 Bit - No Sound
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ forums
PC Version Technical...
Hercules RMX...
Author - Topic: Hercules RMX With Window 7 64 Bit - No Sound -
reggie2167
Professional edition user
Posted Fri 06 Nov 09 @ 4:17 am
OK, I've been using VDJ for a long time and I have a bizzare problem. I recently upgraded my Dell Inspirion 1521 laptop to Windows 7 64 bit. I reinstalled all of the latest software and drivers, however, I have no sound coming from the RMX. The controller works and I have sound from the laptop sound card. I reinstalled the firmware and VDJ. I tried everything that I know to get it to work, but I am having no success.
Has anybody tried Windows 7 64 Bit with the RMX? If so, do you have any ideas on what could be the problem?
DJ-BigReg
DJ Phatso
Experienced pro user
Posted Fri 06 Nov 09 @ 6:33 am
Is the Rmx installed correctly , as described in this document:
http://ts.hercules.com/faqs/eng/her_eng_00350.pdf
Does the Rmx soundcard works outside of VDJ, with something like Windows Media player or iTunes ?
reggie2167
Posted Fri 06 Nov 09 @ 11:19 am
Yes, when I use Media Player, it works fine. However, when I start VDJ, it knocks out the sound on my laptop. However, when I restart my computer, I can play my windws media player.
What do you think is going on?
DJ BigReg
TearEmUp
Senior Moderator
Posted Fri 06 Nov 09 @ 1:39 pm
Can you post a screen shot of your sound settings for us?
DJ Phatso
Posted Fri 06 Nov 09 @ 1:43 pm
If the Rmx can be use like a normal soundcard , they the problem is most likely with VDJ. Sounds like:
a) The audio configuration in VDJ is not setup properly. It should be:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console RMX > Apply EQ on external source
b) if you set it that way AND every time you launch VDJ it defaults to your onboard soundcard, it could be that the configuration file is not being save, possibly because it is in read only, or your are not an administrator mode.
reggie2167
Posted Fri 06 Nov 09 @ 2:16 pm
OK I finally got it to work. I had to change the sound card to 4.1 and it is working. Also, I had to restart my computer. The DMX option does not work for some reason. However, it used to work in Vista SP2. This is strange.
DJ BigReg
reggie2167
Posted Fri 06 Nov 09 @ 4:17 pm
I played around with it for a while, but it is not stable. I was doing some scratching to see how it handled it, but the RMX just blanked out on its own. I closed the program, unplugged and then plug the RMX back into my laptop and could not get any sound. So, I restarted my laptop and got it to work again. There is definitely a conflict in the software driver.
Thanks,
DJ BigReg
Site map
Software
Membership
Goodies
VirtualDJ Pro Full
VirtualDJ Pro Basic
VirtualDJ Broadcaster
VirtualDJ Home FREE
VirtualDJ LE
Comparison
Numark CUE
VirtualVinyl
VirtualDJ iRemote
AtomixMP3
eJay DJMixStation
DJ-Box
What's new
Features
Screenshots
VirtualDJ Home FREE
User Manuals
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Effects
Controllers
Languages
Samples
Grafx
Tools & Drivers
Forums
Users Network
Music Groups
Wiki & Manuals
Radio
Magazine
Social Web
Create a login
Atomix Productions
Privacy Policy
VIP DJs
Ask a question
View your tickets
Wiki & Manuals
