Forum: Hardware Technical Support - Topic: Hercules Mk2 need solutions
Please post here all questions or comments about the hardware supported via HID or MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ forums
Hardware Technical...
Hercules Mk2...
Author - Topic: Hercules Mk2 need solutions -
HKNYC
Professional edition user
Posted Wed 04 Nov 09 @ 6:07 pm
I´ve made all updates to the MK2 im running on vista 32 bit Intel Pentium dual cpu T3400 @2.16 GHZ Mobil Intel 4 series express chipset family.
The problem im having is the joy stick is no longer working properly since the updates. It does´nt respond exactly as it used to and I have to scroll through my music crate with my mouse pad.
Is this a bug or what? All else seems to work fine can someone give me a solution much appreciated.
FLeX69
Posted Thu 05 Nov 09 @ 6:04 am
Mine never worked exactly they I wanted it too, ever since I had it.
With the new VDJ, I'm able to use the pitch knob to scroll through my tracks w/ a shift key and the joystick is an alternative.
I probably didn't answer your question, but last night I added a few multiple function keys on my MK2 because of never liked the way the joystick worked.
Maybe its something in the code.
HKNYC
Posted Thu 05 Nov 09 @ 10:01 am
Actually I´ve had mine for over 3 years I think... And I never had a problem with it always worked very smooth. Once I did notice they made a new update for it and it began to make noises.
Like it would buzz everytime I used the jogwheels you could hear it externally and in my headphones. But it was fixed with another update and this last update for some reason is doing this new thing.
The joystick works occasionaly I have to keep moving it until it finally grabs its wierd but annnoying. Specially when I know how well it was working.
All the other function work well, I think the main problem here is that they keep making all these controllers, and keep mixing up the all the firmware.
I think each one should have exclusive firmware and updates, damn don,t be lazy make a quality product.
Site map
(C)opyright Atomix Productions 2009
Software
Goodies
VirtualDJ Pro
VirtualDJ Basic
VirtualDJ Home
VirtualDJ LE
Comparison
VirtualVinyl
Numark CUE
AtomixMP3
eJay DJMixStation
DJ-Box
What's new
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Music Groups
Wiki
Radio
Social Web
Create a login
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
