Forum: Hardware Technical Support - Topic: vdj 6.0.2 and dn-s1200 help
Please post here all questions or comments about the hardware supported via HID or MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ forums
Hardware Technical...
vdj 6.0.2 and...
Author - Topic: vdj 6.0.2 and dn-s1200 help -
cpg300
Professional edition user
Posted Tue 08 Sep 09 @ 8:48 pm
Hi everyone...this is my first time learning this amazing new hobby for me. For my first set I have purchased a pair of dn-s1200 and a dnx120 mixer and running it to a pc with vdj. Everything seems well and working expect for one thing. My push/play, cue, pitch, scratch all function in sync with the vdj software...but the flanger, echo or loop effects on the actual deck do not work. For instance if a track is playing and I hit the flanger on my dns12 the vdj will give the break effect. I'd guess this would be bc of midi mapping? Can it be corrected? And if so how. I was under the impression these are now native to vdj and i thought there would be no mapping required. Any advice or help would be greatly appreciated. Thanks all in advance.
shaggypoet
Experienced pro user
Posted Tue 08 Sep 09 @ 9:04 pm
You have to tweak the Denon Mapper within VDJ to use the effects you want. In other words, add or edit the existing MIDI shortcuts to make it do what you want...
Posted Wed 09 Sep 09 @ 1:08 pm
With the default mapping, you can press MEMO to assign effects of your choice to the buttons. Follow the instructions on the display of the S1200.
Or you can edit the mapping manually:
  • Go to CONFIG -> Mappers
  • Choose the S1200 in the drop-down list.
  • Choose the button you wish to change from the list.
  • To activate an effect, map it to the following: effect 'Name' active - E.g: effect 'Flanger' active
cpg300
Posted Thu 17 Sep 09 @ 10:06 pm
Thnx JP...that worked great. Another ques if u dont mind. When playing the dn-s1200 without vdj you can use the wheel to deepin the effect, is this possible with the midi mapping or no?
And one last ques...I have seen the hercules rmx and vdj LE work great where it is completely user interface and when you adjut volumes and gains, fader ect you see the changes in vdj as well. Can this be done with the dn-s1200 and my mixer? Im using vdj pro 6.
thnx for all ur help, greatly appreciated as I am new to this.
Posted Fri 18 Sep 09 @ 12:32 pm
In the default mapping, that's not possible, but you could do this be modifying the mappings, e.g;
Map the parameter knob to the following:
effect active ? effect slider 1 : browser_scroll
Map the parameter knob press to the following:
effect active ? effect button 1 : browser_enter
Map the jogwheel to:
effect active ? effect slider 2 : touchwheel
And map the jogwheel touch sensor to:
effect active ? nothing : touchwheel_touch
With the above, when an effect is active the parameter knob will adjust slider #1 (Normally wet/dry (Volume)) and the jogwheel will adjust slider #2. Pressing the parameter knob will press the 1st button of the effect.
djnickvee
No license user
Posted Sat 07 Nov 09 @ 8:09 pm
so i have dn-s1200s and ive been trying to hook them up to vdj first it keeps telling me error in sound driver not enough channels??? idk what that means and i have a dnx-500 mixer but i can play a song and hear it and use my mixer but i cannot function the turntables do i have to have d link connected ? and how i really am just completly lost i apprciate all the help i can get i just started djing couple months ago plzz heelppppp !
Site map
(C)opyright Atomix Productions 2009
Software
Goodies
VirtualDJ Pro
VirtualDJ Basic
VirtualDJ Home
VirtualDJ LE
Comparison
VirtualVinyl
Numark CUE
AtomixMP3
eJay DJMixStation
DJ-Box
What's new
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Music Groups
Wiki
Radio
Social Web
Create a login
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
