| Author | - Topic: Hercules Mapper Pack for VDJ 6.0.2 - v1.4 - |
I made some changes to the default mapper for Virtual DJ v6.0.2 with Hercules HDJC(MK1) - MK2 - MP3 - MP3 e2 - RMX & Steel. The mapper that you have downloaded it to unzipped and copy/overwrite in the old path C:\Documents and Settings\User Name\My Documents\VirtualDJ\Mappers (do it with Virtual DJ closed). v1.4 - Added new Hercules MP3 e2 mapper with same modification of MP3 plus an advance configuration of the 4+4 buttons v1.3 - Hercules RMX & Steel code updated for v6.0.2 v1.2 - Unload the track from the deck change button, hold on the load button (not stop) for more than half a second - Added Hercules HDJC(MK1) mapper with same modification of MP3 v1.1 - Added blink on Fx and Loop leds when Fx or Loop are activated (Only Hercules MP3-MK2) v1.0 - Ability to change the parameter 1 of effect active, when an audio effect is active the rotation of the Jog change this parameter (as on the Pioneer CDJ-100s), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch (No Hercules Steel). - Ability to scroll fast within the track with Jog, just press the |< or >| button and rotate the Jog. - Possibility to unload the track from the deck, hold on the stop button for more than half a second. (Only Hercules RMX-Steel) - Ability to make "browsing" of the tracks with jogs, simply hold the "Cue Select" button on the deck and rotate the Jog. (No Hercules MK2) Note: that only works on one deck/jog at one time. - Added blink on Play/Pause buttons when the song is paused. (No Hercules Steel) ![]() Download -> http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html |
Hello Cioce!! I had Hercules Rmx I done everything that you wrote,but i can t still scroll fast with Jog!! Everything else is OK. Cant you please help me! |
Love the ideas, thanks! |
fratello73 wrote : Hello Cioce!! I had Hercules Rmx I done everything that you wrote,but i can t still scroll fast with Jog!! Everything else is OK. Cant you please help me! Try looking at this thread for some ideas ;) Thanks for the mapper changes, cioce :D |
v1.1 - Added blink on Fx and Loop leds when Fx or Loop are activated (Only Hercules MP3-MK2) Download -> http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html |
v1.2 - Unload the track from the deck change button, hold on the load button (not stop) for more than half a second - Added Hercules HDJC(MK1) mapper with same modification of MP3 |
v1.3 - Hercules RMX & Steel code updated for v6.0.2 |
"Limited" users cannot download it. Thank you anyway. |
"Limited" users cannot have a legal version of Virtual DJ 6.0.2 PRO, the solution is here http://www.virtualdj.com/buy/index.html |
I'm happy with my legal version of VirtualDJ :) |
Hi Cioce, I just bought a RMX and am using VDJ LE that came with it. I love the way VDJ 5.2 has the RMX mapped. I've been testing VDJ6 with the RMX and can't stand the way the RMX is mapped in 6, and this whole VDJscript stuff is way over my head. If I buy VDJ6 and download your mapper, will the RMX behave as it did in 5.2? I'd hate to waste $150 on something I don't need. If I could get the jog wheels to control the effect sliders like 5.2 did, I'd be happy to upgrade to Pro6. I like 6 a lot more, I just need to get this RMX sorted out. Thanks for any help or advice! |
With my mapper you can ;) http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html - Ability to change the parameter 1 of effect active, when an audio effect is active the rotation of the Jog change this parameter (as on the Pioneer CDJ-100s), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch (No Hercules Steel). |
Are there any combo mapper? Since some need for both keyboard and RMX at the same time |
You activate both keyboard and the RMX at the same time. You can map them both seperately so there is no need for a combo. |
thx big time |
v1.4 - Added new Hercules MP3 e2 mapper with same modification of MP3 plus an advance configuration of the 4+4 buttons Download -> http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html More info about new MP3 e2 -> http://www.hercules.com/uk/DJ-Music/bdd/p/110/dj-control-mp3-e2/ |
Hello friends ............ I have a hercules mp3 and I need a help for MAPPER. I would love to test my midi controller in the demo version of VirtualDJ 6:02 but I have limited access to the site and I can not download the plugins (mapper) children. someone with access could send me: xxx@hotmail.com I thank those who help me. hugs Edit By Cioce "Limited" users cannot have my mapper and 6.0.2 Demo is not avaiblable. |
i cant get my Board to work but i can get the sound out of it but cant control nothin i need help bad |
