Forum: VirtualDJ Plugins - Topic: Problems installing slideloop fx [not compatible with VDJ-Cue 4.x & 5.x]
Post here comments on the VirtualDJ Plugins (Audio effects, Video effects, Video transitions, Tools, ...).
Plug-ins are available for download by registered PRO License users only.
VirtualDJ forums
VirtualDJ Plugins
Problems installi...
Author - Topic: Problems installing slideloop fx [not compatible with VDJ-Cue 4.x & 5.x] -
djsynystr
Professional edition user
Posted Mon 12 Jan 09 @ 8:15 am
when i click on it to install it tells me i don't have virtual dj installed. i run Numark cue is this the reason?
arrowjpg
Posted Thu 15 Jan 09 @ 3:58 am
Same here please help.
SBDJ
Atomix Productions
Posted Thu 15 Jan 09 @ 6:27 am
It does predate Numark Cue, so the installer probably doesn't recognise it.
You could install the trial of VDJ, then copy the plugin over?
djsynystr
Posted Fri 16 Jan 09 @ 7:17 am
thats kinda what i figured. oh well no sideloop then.
sischo
Banned
Posted Fri 16 Jan 09 @ 7:47 am
I know why slideloop doesn't work.
This is a very old effect and when they made it, VDJ was different; some years ago, all the effects were installed in Effect folder while today in Plugins\SoundEffect.
So go in VirtualDJ/CUE folder and open the EFFECTS folder: inside it you will find sliderloop.dll, cut and paste sliderloop.dll in Plugins\SoundEffect folder, start CUE and enjoy your new effect!!!!;-)
SBDJ
Atomix Productions
Posted Fri 16 Jan 09 @ 8:56 am
If you install the VDJ trial, it should detect it and install. You can then copy the plugin across as per the previous members post :)
sischo
Banned
Posted Fri 16 Jan 09 @ 9:04 am
what about the modify the old .exe to allow CUE users to install each plugin as well?
cioce
Moderator
Posted Fri 16 Jan 09 @ 9:05 am
It will be fixed soon, only moderators and teamers can ;)
SBDJ
Atomix Productions
Posted Fri 16 Jan 09 @ 9:15 am
I'll just go sit in the corner then :p
sischo
Banned
Posted Fri 16 Jan 09 @ 11:15 am
Cioce, if you fix this the destination folder and this issue for CUE users for all old .exe files, I am sure most users will say thank you;-)
JeremK
Senior Team
Posted Sat 17 Jan 09 @ 7:32 am
I was going to fix it, but first I tried the effect in VDJ.
And it doesn't work correctly.
As this is an old effect for VDJ 2.xx and 3.xx, I didn't fix the installer, and I added a note on the download page to say it isn't compatible with 4.xx and above.
sischo
Banned
Posted Sat 17 Jan 09 @ 7:48 pm
Ok.
Thank you so much JeremK.
pOpYDJ
Posted Sun 25 Oct 09 @ 12:36 pm
Could anybody please make this one compatible with VDJ6.
Thanks
cu
pOpY
Site map
Software
Membership
Goodies
VirtualDJ Pro Full
VirtualDJ Pro Basic
VirtualDJ Broadcaster
VirtualDJ Home FREE
VirtualDJ LE
Comparison
Numark CUE
VirtualVinyl
VirtualDJ iRemote
AtomixMP3
eJay DJMixStation
DJ-Box
What's new
Features
Screenshots
VirtualDJ Home FREE
User Manuals
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Effects
Controllers
Languages
Samples
Grafx
Tools & Drivers
Forums
Users Network
Music Groups
Wiki & Manuals
Radio
Magazine
Social Web
Create a login
Atomix Productions
Privacy Policy
VIP DJs
Ask a question
View your tickets
Wiki & Manuals
