| Author | - Topic: @Apopsis "TimeCODE POWER" skin - |
- This skin will have more space for the music and browser than any other skin - ...while it will not miss anything : 12 SAMPLES - Aythor-title-comment-timecode-master tempo-bpm-pitch-4 cues per deck +++full mixer:volume-gain-3bandEQ+ fader Eq's+kill switches +3 effects per deck+master+crossfader VU METERS... loops from 1/8 to 32 beats.. - No pannels ... no tricks... Yes its possible... Wait and see.. Very soon. -Question... where is the play button ? he he... |
can you send it to me by mail ? |
hey apopsis, looking forward to this one.. any sneak previews like i've been doing? |
Here is a preview of the skin, simple design, no buttons but 2 display showing everything happens to the program, (from loops to eq's and beatlock) by using keyboard-external controllers-Timecode. In this example you can see player 1 with 4 cue points play a 16 bar loop, master tempo and timecode enable on both decks and sample #8 is playing. NO PANNELS http://img1.imageuploader.net/119/@TIMECODE_POWER-PREVIEW1.jpg I'll post it on the skin page soon. |
cool.. very minimalistic.. i can see why this will appeal to TC users.. i still need to get on with my skin =\ |
Great work Apopsis. Fabio. |
I just posted the skin on the skins page Here is the included description: - More space for the music and browser than any other skin (until now...) - Designed for users with ext controllers (keyboard shortcuts, midi, Timecode) - No buttons, no sliders only displays full of informations :12 Samples - Aythor-Title-Comment-Timecode-Master Tempo-Bpm-Pitch-4 cues per deck +++full mixer (volume-gain-3bandEQ+ fader Eq's+kill switches +3 effects per deck+master+crossfader) Loops from 1/8 to 128 beats, and A-B displayed... - Colour coded (easy to read) fonts - No pannels, 5 colour variations. *Hidden features: click on the big timers for play/stop, Beatlock ON indicator is a small star in the right corner of the display) |
very good work the fonts are too small (songs) |
I'm currently working on your skin I hope you don't mind Apopsis. Things i've changed are the player layout the fonts on the players were way to small I also increased the font size in the record case. And I made some space under the players to make room for cues and looping. let me know what you think email me at djcyder(@)insightbb.com if you like a copy or if you want to help me finish this remix section. here is a link to the progress http://www.imagestation.com/picture/sraid158/p2e68dc43962d0972fd611df16a7627f2/f51af254.jpg |
I can't see the difference from the photo except the empty room under the players. I made the skin without "set" or "go" to cue, and loops buttons, i have a keyboard full of shortcuts for this. The only i needed was a quick and easy way to view the status every time, thats why i made the LCD displays... You can make your version, just refer to the original skin and poster if you post it. In the meantime i also made some small changes, updated once and will update it again now. My e-mail is in my profile if you want to send me your changes when you finish. |
The main difference in mine vs yours is the player track title layout artist - title I agree the set and go to is redundant I'll email you my version take a look at this version look closely at the players http://www.imagestation.com/picture/sraid158/p33c40b42adda57cad4f028613c897eb6/f51aaf2a.jpg |
I see, you put artist-title at the same line, but there is no room for "comment" now Also by doing this, more scrooling for big names is needed. Just my thought. |
I'm currently fixing this the plan is to get rid of the mixer section and make the players bigger, I tried to emal you the skin but it bounced have no clue why. |
i download the file but i can't open it. i would like to use the skin but i am unable to open or apply it to vdj help dj@gvmusic.com |
To Cyder: I made the background without the mixer/eq in the middle for you, and i will send it to you to make the changes in the xml. I dont find it a good idea personally because i need the eq. But this can be a "lighter" version. To gvmusic : What is the problem ? did you download the zip file, someone reported the file downloaded without the zip extension, no problem for others, but check the .zip extension. |
I've just finished the revamp of Apopsis' TC Power skin to 1280x800. Apopsis - I sent you an email with the zip for you to take a look at if you want to comment before I post it up to the SKIN dwnld area. In the meantime, all you 1280 users and anyone else, if want a copy - just shoot me an email (found in my BLOG). There are a lot of cleanups I plan to do... cut the BMP file down in file size by removing all unecessary graphics make a version without the H,M,L crossfaders in the center JUST a few ideas now... If you have others please let me know. cstoll |
Apopsis, Wow I was having a real tough time making the skin work without the middle section. My email is djcyder (at) insightbb.com |
I've read both, but its 4 in the morning now... tomorrow .. |
i just click on download and cant open file, it doesn't look like a zip file |
But it is, try to add the .zip extension by hand, what browser do you have ? (its working well for me, winxp, sp1 IE6.0X) do you use any download manager ? other skins ? are they working ? Do you have the file extensions to be hidden ? (tools->folder options->....) |
